Philco 41-290X Band Selector help
My Philco 41-290X has two cords: one for the tuning dial and the other for band selector. Luckily, the turner is still strung but the cord for the band selector light box was broken when I acquired the set. Does anyone have this set and can show how to string it? There is a rotating switch, the turning of which moves the cord whin in turn moves the light box to indicate the band. And, newbie that I am, I can't tell even which position the switch should be in to start the re-cording. Any clues, or where to look would really help!
Thanks!
=-jp-=
This thread might be of help:
http://www.philcoradio.com/phorum/showth...p?tid=1502
Ron,
You are the man of the hour! That was exactly what I needed and I was able to get it working. Thanks again!!!
=-jp-=
