What grill cloth for 40-190?
I kind of know but who has the best price?
It looks like the diamond pattern is on most so you can get it from Kenny richmond on ebay.
His is the closest to original...
There are more than one but here is a link to his items..
http://www.ebay.com/itm/Antique-Radio-Sp...Sw-7RVF29S
There are currently 10538 online users. [Complete List]
» 2 Member(s) | 10536 Guest(s)
