Philco 20 Cabinet Reproduction
Threads: 72
City: Linn Creek, MO
I have been thinking about making a 20 cabinet for sometime. The biggest holdup has been trying to figure a way to cut the scroll in the front panel. The only way that I could think of was an over arm pin router. I couldn't afford to buy one so, I took an old cheep Black and Decker router that I have had for years and made one. It's a little crude but it works pretty well.
[Image: https://farm6.staticflickr.com/5449/2978...575e_k.jpg] Homemade Overarm Pin Router by Steve Davis, on Flickr
[Image: https://farm6.staticflickr.com/5783/2978...dd2d_k.jpg] Homemade Overarm Pin Router by Steve Davis, on Flickr
And the finished front panel.
[Image: https://farm6.staticflickr.com/5827/2967...c568_k.jpg] Philco 20 Replacement Front Panel by Steve Davis, on Flickr
It may be a while before we have a complete cabinet. I still have to grind a set of shaper knives to make the base moulding.
M R Radios C M Tubes
(This post was last modified: 09-17-2017, 11:38 PM by Steve Davis.)
Threads: 22
City: Waxahachie, TX
Threads: 562
Wow, Steve...you are a regular wizard, do you know that?
Threads: 54
Another method might be to use a Dremmel with a router plate attachment, thought one would have to make a jig for it unless you have steady hands. A lot of cabinets have grooves cut into them in that way to add details like a frame around the dial, or to make a fake panel, it's nice to see a practical way to reproduce such a detail.
Threads: 72
Arran, the problem with using an ordinary router (or Dremel router) with a pattern on the top side would be the curly-que near the bottom. With the over arm router, there is a guide pin located directly under the router bit that follows a pattern on the underside of the work piece.
The pattern used to cut the vein and the grille.
[Image: https://farm6.staticflickr.com/5672/2978...26ec_k.jpg] Philco 20 Front Panel Pattern by Steve Davis, on Flickr
(This post was last modified: 09-17-2017, 11:41 PM by Steve Davis.)
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 310
City: Kings Park NY
(1) 20 deluxe front panel please!
me
AC: 4 DC: 1
Threads: 562
No....there are way more those than plain ones in good condition....or at least it seems so.
And the plain front panel to me is more intricate, this curly groove is harder to make than to just slap a piece of pre-cut wood at the top.
Threads: 414
City: Boston
There are many talented people here, neat to see a gifted woodworker ply his craft. Thanks for the photos Steve.
Threads: 11
City: Bellmawr, NJ
Need a ARM,,,like when doing spindles,,,,to follow old Pattern,,on wood
Threads: 72
(This post was last modified: 09-17-2017, 11:56 PM by Steve Davis.)
Threads: 214
City: Seattle
State, Province, Country: WA
Threads: 562
really, Steve, when I watch your work it's like watching Sorcery.
I can't wait to see the finished product but I am sure this will be a marvel.
If I wore hats, they'd all be on the floor right now.
PS. BTW, are there nails at the bottom in the original cabinet or not? If not, are you going to somehow conceal them?
PPS. I still consider this cabinet more complex in making than the DeLuxe version. Or for that matter, any of the Coombs designs.
Am I wrong?
Threads: 69
City: Kansas city, MO.
Excellent craftsmanship!!
Living at the lake and building radio cabinets what a way to live.
Threads: 22
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
