39-55 Pilot Light
Is there supposed to be a bezel or lens of some type for the front pilot light of the 39-55?  Haven't seen one pictured that has any kind of bezel, a red tipped bulb stuck in a hole just doesn't seem right.
Chris
KD7WMZ
Visit Chris' Old Radios and Precision Tube Testers
http://oldradios.50webs.com/index.html
It had a little red piece of plastic in the hole, no bezel. Original was tenite and has turned to dust.
Mystery solved! Thanks Terry.
Chris
KD7WMZ
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
There are currently 2988 online users. [Complete List]
» 3 Member(s) | 2985 Guest(s)
