RE: Ron's Pioneer SX-1500TD
Ron,
Wish you hadn't closed that thread. Please keep us up to date on your progress (you can do a read-only thing on these, can't you?
Yeah, I was following the thread also.
M R Radios   C M Tubes
Me to also.
I was also enjoying that thread, a lot of good info to be learned.
Okay, folks, point taken.
http://philcoradio.com/phorum/showthread...#pid105228
That thread is open again - this one is closed. Thanks for your input, it is appreciated.
Philco 91 Tuning Condenser
There are currently 8315 online users. [Complete List]
» 2 Member(s) | 8313 Guest(s)
