What's the difference between 551 and 52 clocks?
The cabinets are identical, according to the gallery.
And, the 52 and 51 radios use the same chassis, so then if 551 uses 51 chassis and 52 uses 52 chassis (identical to 51), with no difference in cabinets, other than labels maybe, is there a difference between the 551 and 52 clocks?
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 7477 online users. [Complete List]
» 2 Member(s) | 7475 Guest(s)
