Philco 20 cathedral conversion?
Has anyone out there ever converted a regular model 20 cathedral to a deluxe model? Do they make repop burlwood fronts and the columns below them?
There are few plain 20 cabinets that are in good enough condition to convert. If I had one in good condition, I would want to keep it original.
M R Radios   C M Tubes
I would never convert. I had harder time finding the plain in good shape than the Deluxe.
Plus...what to do with the grooves? Deluxe does not have them and the bezel does not cover it.
I would advise against it.
Okay, just a thought. I didnt know if the columns would cover them or not. Ill leave it as is.
Just because ... I see this name "repop" from time to time .... what is "repop"? I can't find any company name that even comes close .... obviously I am stupid, but I'd like to know.
cheers
John
I think it is slang for "reproduction item".
Repop is reproduction. You make a copy and pop them out one by one.
I think you're pulling my leg Kirk .... I checked the online dictionaries before I posted and I didn't see what you posted, but .... I found "repro" (short for "reproduction"), so I'm guessing that "repop" is some new sort of rapper slang.
Thanks all.
cheers
John
John
No, Kirk is serious (for what may be the first time Icon_lol). I have heard - and read - the same expression (repop) numerous times.
I would assume that slang term isn't used in Canada.
Just like we don't end most of our sentences in "eh?"...
Icon_wink
No offense intended, I assure you.
http://www.camaros.net/forums/11-bench-r...repop.html
http://bmxmuseum.com/forums/viewtopic.php?id=270231
(04-08-2016, 05:35 PM)Ron Ramirez Wrote:  John
Icon_wink
What??  Kirk being serious??  The world as we know it is coming to an end.....
Ok, I've learned something today, but I think I'll keep using "repro". Repop just doesn't do it for me, and as for "repo", I think we should try to avoid having anything of ours being "repo'd" .... eh? Icon_smile
cheers
John
Agreed, yes...using the term "repo" in place of the term "repro" is just very poor English. "Repo" indicates a shortened version of "repossessed", not "reproduction".
We now continue with our regularly scheduled program of a Philco 20 cathedral cabinet...
Ron
They said "repop", nor " repo". Like in "Repo man" with Emilio Estevez Icon_smile
Still bad English Icon_smile
Mike (morzh)
Man, I love ya like a brother, but...
I know they said "repop". I was answering John B. when he mentioned "repo" by seeing it in the first link I posted (the Camaro forum, post #2)...
Quote:Re: What's definition of "Repop"?
<snip>
Just a term used for repo or repop parts.
Repop - Slang for reproduction or remake
Repro - Also slang for reproduction part, item, etc.
Repo - Slang for repossession, repossess, repossessed
Missed that one, sorry Icon_smile
Never heard "repo" in that sense anyway.
There are currently 9451 online users. [Complete List]
» 1 Member(s) | 9450 Guest(s)
