Speaker wire colors
I would like to know what the wire colors were on early 1930s Philco sets. Specifically, I have an 89 THAT I CAN'T GET TO OSCILLATE. Today, they are all straw-colored. I'm sure one of the wires
Had a black leader stripe in it. I'll never find any of that! But I want it to look authentic. Which colors?
Hi Steve,
I'm not sure specifically about your 89 but I tried to assemble an authentic looking wire harness for my 16B in this thread:
http://philcoradio.com/phorum/showthread.php?tid=12753
You may be able to figure out the original wire colors from the portion on yours that was under the chassis - or look around the web for more pictures from better preserved examples.
Here's a picture of an 89B harness (not entirely faded):
And according to the service bulletin (#146B):
So the wires are green, white and green & white.
Hmmmmmm...I wonder if I could make that Green/white wire out of a white wire and a green Sharpie......? lol
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8395 online users. [Complete List]
» 3 Member(s) | 8392 Guest(s)
