my Precision 10-12 arrived today
Threads: 114
City: Sneedville, TN
My Precision 10-12 arrived today. It is the model in the metal counter top cabinet, which I have not seen nearly as often as the one in the wooden box. Is it rarer ? I am looking forward to going right through it. I have heard they are an excellent tester, and I have the manual.
[Image: http://36.media.tumblr.com/158fce7784eed...1_1280.jpg]
Threads: 562
Is it a transconductance tester? If yes good, if not, unless you collect them, my personal favourite is Hickok, any from 5xx to 800 series.
(I wanted 539 but settled for 600A, an excellent tester for a radio repair).
Threads: 114
Radiomuseum says, "The Series 10-12 Electronamic Tube-Master is simple push button, master-lever type operated Vacuum tube and battery tester, incorporating the Electronamic Master tube testing circuit, designed by Precision engineers to indicate the overall performance merit of a vacuum tube in only one direct meter reading. ", and, judging by the schematic, http://www.antiqueradio.org/art/Precisio...ematic.jpg , I would say it will do all I need it to. If you notice, it has the headphone connection for noise test, as well as all the short and transconductance tests.
Threads: 114
Oh, and, if anybody needs the manual for this model, or the 10-15, which is the same manual, here is a link to the PDF of it http://sh1.webring.com/people/gc/cghwort...p_Inst.pdf
Threads: 31
City: Lapeer
State, Province, Country: MI
(03-25-2016, 02:52 PM)mikethedruid Wrote: Oh, and, if anybody needs the manual for this model, or the 10-15, which is the same manual, here is a link to the PDF of it http://sh1.webring.com/people/gc/cghwort...p_Inst.pdf
Nice unit, I'd never seen one in the metal cabinet. Make sure the metal cabinet is isolated.
Joe
Joe
Threads: 114
Yup, gonna swap the old 2 wire cord for a 3 wire, and ground the cabinet too.
Threads: 114
Been looking all over the net for another 10-12 in a metal case. Haven't found one yet. It am sure it is a factory job. It must not be common. It obviously has had some plates removed that may have been ID of some sort. It may have been surplus, military or industrial, but there are no markings left to know. If anybody knows, let me know. I see 10-15s in metal, but they are quite different, the case looks different too.
Threads: 4
City: Springdale, Ar
The 1950 Presision catalog lists the model 10-12C as the heavy gauge steel counter cabinet for $106.50. The 10-12P is the closed portable in the wood case and the model 10-12 PM is the panel mount. The 10-15 is the vertical counter model with the 9" meter, havent seen many of those, $143.50 on the Oct 1950 price list.
Chris
KD7WMZ
Visit Chris' Old Radios and Precision Tube Testers
http://oldradios.50webs.com/index.html
Threads: 114
Thanks a lot Chris ! Great information !
Threads: 7
City: Medford, Oregon
The 10-12 features "Electronamic" tests. It is actually an emission tester, but it's a darn good one. I have a 10-12. I've never been able to find documentation of the calibration process, or anything from the factory, so I've never messed with it, but it tracks well with my CALIBRATED Hickok testers. I use a TV-7 to check tubes. I even have a spare TV-7. I have around 30 testers, most of them Hickoks or military testers. If you can find one, replace the 5Y3 with a 6087.
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
There are currently 8773 online users. [Complete List] » 3 Member(s) | 8770 Guest(s)
