Philco 89B won't oscillate!
Threads: 7
City: Medford, Oregon
I have done a detailed Voltage check, along with a resistance check on my 89B. It WILL NOT oscillate! The O-coil isn't open but has evidently lost its Q. I also used a tracer/injector to inject signal into the top caps. Every one but the oscillator tube (36), I can hear my tone. But the 36 acts dead! Underneath, I can inject signal and get a tone on the coils, even on the block condensers that are in the signal chain.
So I am forced to pull the O-coil and cook the water molecules out. si-i-i-i-igh....well, there are only 5 wires attached to it.
If I have to, i'll install a 77 in place of the (*&(&%^$) 36. There's a how-to article on Chuck Schwark's Philco Repair Bench site for that job. I'll have to swap out even the tube socket! 36 is a 5-pin tube, 77 has 6 pins. And I will have to rewind the O-coil. That's a real job! Wish me luck!
(This post was last modified: 04-13-2016, 08:12 PM by Steve McDonald.)
Threads: 566
Don't de-solder the coil, bite it out as close to the pins as possible, then clean the lugs.
The wires should have a little slack to be able to solder them back when the coil is reinstalled.
Threads: 7
You're right! It's ridiculous to try and save that 1/8" that was soldered. Sometimes I may have to solder a piece of wire in so as to reach. But the O-coil is hard enough to remove in the first place.
SM
Threads: 268
So if you measure the resistance from pin 4 of the 36 tube to the pin on the osc coil that has the resistor (15K) and cap (700mmfd) connected to it what do you get???
(This post was last modified: 04-13-2016, 06:40 PM by Radioroslyn.)
Threads: 7
(04-13-2016, 06:31 PM)Radioroslyn Wrote: So if you measure the resistance from pin 4 of the 36 tube to the pin on the osc coil that has the resistor (15K) and cap (700mmfd) connected to it what do you get???
Terry, I don't see a resistor or capacitor going to the O-coil. But pin #4 of the 36 goes to pin 1 of the O-coil. From that point, I get nothing- open on the other 4 pins. . I get 8.5 Ohms from the top cap 36 to gnd. O-coil OPEN?
SM
(This post was last modified: 04-13-2016, 07:20 PM by Steve McDonald.)
Threads: 268
http://www.philcoradio.com/tech/images/89v1.jpg Parts #8 & 10
Well should be a cap and resistor connected to the osc coil. What is the resistance from chassis ground to pin 4 of the 36 tube
Threads: 7
(04-13-2016, 07:34 PM)Radioroslyn Wrote: http://www.philcoradio.com/tech/images/89v1.jpg Parts #8 & 10
Infinity
SM
Threads: 7
Mine is code 123. That schem (as well as the one I have) is for code 121. I see the components you mean. Pin #4 36 goes directly to pin 1 of the O-coil on this one.
SM
Threads: 268
You've got me a bit confused. The code 123 has a 77 mixer tube the 121 has a 36. If you have a 36 tube use pin 4 or if you have a 77 use pin5. http://www.nostalgiaair.org/pagesbymodel...013877.pdf
Ok now your are looking for #8 and9 (code 123)
The osc circuit is about the same just different tube. If the connect your ohm meter to pin 5 you should be able to find a low resistance (like less than 10 ohms) connection on the osc coil that isn't directly connected to pin 5 if the coil is ok.
(This post was last modified: 04-13-2016, 08:53 PM by Radioroslyn.)
Threads: 7
Mine is definitely code 123- With a 36 oscillator.
SM
Threads: 268
Go with pin 4 and find #8 and 10.
Threads: 7
Part 8 is a block condenser (8174-B) and the 15K resistor is across 2 pins of it. It has NO electrical connection to O-coil- although it DOES have connection with the interstage coil.
SM
Threads: 7
woops....Radioslyn gave up on me. Well I will look to see if there are running changes in the folder I got from our pal Chuck. Wish he or Ron was here!
Edit: All kinds of changes in the coils! Ay ay ayyyyy Anyway pin 4 of 36 (cathode) goes to pin 1 counting clockwise from the bracket of the O-coil. from there to any other pin on O-coil is a reading called ol (nothing). Sounds like I will be pulling said coil. Yuck!
SM
(This post was last modified: 04-13-2016, 10:28 PM by Steve McDonald.)
Threads: 268
No haven't given up yet. Was on another forum. Ok so if you look at the schematic find the cathode connection on the mixer tube. Follow it over and you will see that it goes over to a coil. That is the feedback winding of the osc coil. The other end of that winding goes to the 15K resistor and 700mmfd cap and then to the chassis. That winding is what is what we need to test the resistance of. There are two other winding on that same coil but those are usually ok. Also check the 15K resistor to see if it is open. Just for grins how much voltage do you have at the cathode of the mixer?? Should be pretty low like a few volts.
(This post was last modified: 04-13-2016, 11:22 PM by Radioroslyn.)
Threads: 7
That would be pin 4 of the 36-cathode. This goes directly to the oscillator coil, pin 1. this pin is not connected to the others. 15K resistor reads 12.8 K . One end of the resistor goes to pin 2 of the O-coil. The other end, to ground. And between pins 1 and 2, there is infinity.
SM
(This post was last modified: 04-13-2016, 11:23 PM by Steve McDonald.)
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
There are currently 8043 online users. [Complete List] » 3 Member(s) | 8040 Guest(s)
