39-17 dial scale GLASS resource
Hello:
Is there a resource for the dial glass for a 39-17?
Dave
try Mark Palmquist at
http://67.20.74.185/jmpalm/index.html for the plastic cover
or RadioDaze for the scale
http://www.radiodaze.com/search.php?search_query=39-17
Thanks. Glad I can get it.
Dave
There are currently 9771 online users. [Complete List]
» 1 Member(s) | 9770 Guest(s)
