ID this Bracket on Philco 16B chassis
Can't figure what it was used for.
Original to this chassis.
Bob T
The bracket does not belong there. Someone added it for who knows what.
M R Radios   C M Tubes
+1 what Steve said.
I think it was used tohold an antenna maybe.
Like they said.
Definitely not factory original.  Dealer or owner add-on.
Attached to the other side of this bracket is the Wave Trap Assembly (PHOTO)
Inductive Wave Trap with Compensating Assembly
Items 3 and 4 on Parts list
It is covered with a soft crystal looking material. Do not know what that is
Will clean later and see if coil still good.
Bob T
The Crystal Material looks like the goo when a Battery leaks.
Just had one yesterday AAA Battery leaked and looked the same.
I believe that Bracket was added.
Its use was to hang the Antenna Wire on
I saw another one , not same Bracket , but had about 20 feet of wire wrapped and hung on the bracket.
So I stand by my answer and that is all there is to it.
No don't try to change my mind, it is made up.
Any other ideas Icon_crazy
Bob T
Philco 89 indicator light.
There are currently 4666 online users. [Complete List]
» 4 Member(s) | 4662 Guest(s)
AvatarAvatarAvatarAvatar
