SAMS Record player radio
Ok,
The front had a design of flowers but that was easily removed.
The one side has a veneer lift that someone glued but it was not level so it sanded through the toner.
I would love to spot repair it but that is up to Sam.
I will strip it down and re-tone it tomorrow..
See Sam, It's not all about Mike  Icon_lol
Terry, Yours is so buried that I will not get to it for a month or 2..  Icon_crazy
Me
Kirk
You started working on it
so I'm not letting you off easy  Icon_twisted
I'll leave up to Ron as he did chassis
And will take pic.
To add to phorum gallery
The mean me
I am taking full advantage of this day!
I got up at the butt crack of dawn and started on these 4 cabinets...
I ended up stripping off the side finish as the sanding was too deep for me to color match.
I re-toned it and am now clearing the whole cabinet!
Decal is all gone Sam!
Still looks like it's there???
Icon_think hmm can you put flower decal back on.  it looked better Heart
Icon_mrgreen
Sam
What radio is it?
philco 40-501
Ron restored chassis
http://www.philcoradio.com/phorum/showth...?tid=13618
kirk is refinishing cabinet
radio plays great cant wait to put them back together
then send out crystal pick up to be rebuilt and play a record Icon_thumbup
sam
Wait!,
You need the cart rebuilt? Why didn't you tell me.
What cart is it? I may have a rebuilt one ready to go...
Me
(05-10-2016, 03:17 PM)OldRestorer Wrote:  Wait!,
Me
Kirk
I don't have paper in front of me
But it's a 22 m
Check your email
Sam
The M-22 is a 2.9v crystal so it will probably be best to rebuild it..
I dont have any done right now sorry.
Me
Done 99%
I cant rot or buff out the finish. The curing process needs mucho time so you will have to wax it up in a fe weeks Sam.
Me
