42-854 Portable
Started in on this set, I think it was the top of the line for 1942. Has the BCB and 6 to 15mc SWB. Made up the five section filter cap and stuffed it into the old casing (not all that pretty) Most of the rubber wire is ok so am proceeding carefully. Being a portable the chassis is rather compact making the work slow.
 Lucky the wire is still okay. If you get time put up a picture.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
