Philco 37-61 chassis mounting
My 37-61 came with no mounting hardware or rubber gaskets. Can anyone tell me how the chassis is supposed to be mounted and what size screws/bolts/washers/etc I should get?
I don't have a 37-61 but I suspect its one of the two screws found on this Renovated Radios pages http://www.renovatedradios.com/parts.html
He also has repro rubber parts.
Thanks!
