X2 Safety Cap
I have a radio that calls for a 0.05 uF cap across the mains. It should be replaced with an X2 rated safety cap. Just Radios sells a 0.022 uF or a 0.1 uF X2 safety cap. Will either of those be an OK replacement or should I try to find an exact match.
thanks!
Either is fine.
Thanks mike! Icon_thumbup
Oh....and if someone does not like the inrush, sparks and all, thede isva hood thing called NTC Thermistor.
You have to size them up properly but they are great at preventing plug in sparks and limit inrush to very acceptable values.
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2676 online users. [Complete List]
» 2 Member(s) | 2674 Guest(s)
