Hookup Wire Advice
Pulled the chassis out of my 39-55 I found a couple of months ago and I'm sure you can guess, the rubber wires are completely rotten. I've used salvaged computer power supply cables for years, usually a good color assortment of 18 and 20 awg wire for small jobs. Since the 39-55 has about 2 miles of rubber wires, some quite lengthy,  I need to order some and would like to order an assortment of colors. I know a man can never have too much wire but if I were order some just for radio work, what size, strand count, solid etc. is reccomended  by those who know?
Thanks
Chris
KD7WMZ
Visit Chris' Old Radios and Precision Tube Testers
http://oldradios.50webs.com/index.html
Here's some advice from Ron related to the rubber coated wire problem: http://www.philcoradio.com/tech/wiring.htm
Oh gosh, I've read that article! Questions answered.  Thanks!
Chris
KD7WMZ
Icon_thumbup
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3510 online users. [Complete List]
» 2 Member(s) | 3508 Guest(s)
