Inline fuses by Radiodaze
I bought a couple just in case.
http://www.radiodaze.com/fuse-holders/
#1 at the link.
Now I asked them. The saleswoman did not know. The guy she asked said 250V.
They don't look like no 250V to me.
And, of course , no manufacturer or part #.
PS. Just found 5A/10A one by Littlefuse in Mouser. Seems to be the only one there. And it is $5.60.
Mike;
  Those look like the fuse holders used inline with modern car stereos, which usually deal with 12 volt supplies, I don't know about using one on full mains voltage or higher.
Radio Daze has a representative here on the Phorum - I would encourage you to send a PM to Radiodaze with your questions if they do not reply in this thread.
Restoring Philco 96
There are currently 7071 online users. [Complete List]
» 5 Member(s) | 7066 Guest(s)
AvatarAvatarAvatarAvatar
