Threads: 69
City: Kansas city, MO.
Threads: 562
Any radio that did not kill anyone deserves being saved. As I understand if it did, it would be probably hanged, drawn and quartered and then discarded without a decent burial, so someone having painted it Hideous Bluegreen indicates it did not commit anything reprehensible over its life time. So it deserves the second life.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Hopefully the paint was simply protecting the veneer all these years!
Threads: 414
City: Boston
I would eat the tootsie rolls and think about how to attack that one, what is the plan as they would say on "GO GO Gophers"?
Threads: 310
City: Kings Park NY
We are having twins
Image(s)
AC: 4 DC: 1
Threads: 69
I'm glad you got that one Kirk. I have seen your work and it will be a beauty when your done.
Paint strip day for mine to see what's lurking under that ugly paint.
Threads: 562
Kirk
You will need the new bottom for that one.
Threads: 69
Threads: 271
City: Wilsonville
Yes that is looking good so far!
Threads: 36
City: Brandon, SD
Why would anyone ever cover up that beautiful wood with paint? They should be ashamed of themselves!
Threads: 562
Actually it looks good.
Threads: 69
Did some more stripping today wit citristrip. Only found one flaw on the front just to the right of the escutcheon hole. I'm going to hit it with lacquer tomorrow morning. Too darn hot this afternoon, 99 deg. right now.
[Image: http://i1336.photobucket.com/albums/o654...o7pmig.jpg ]
It also looks like the paint acted as a grain filler so will have to use the lacquer to get it out.
[Image: http://i1336.photobucket.com/albums/o654...8n1jnw.jpg ]
Threads: 11
City: Bellmawr, NJ
YYou have the luck to get something this NICE----GOOD for you,,,happy trail
Threads: 69
Thank you Kenneth. I do feel lucky it turned out as it has. I will post 1 more picture of the cabinet after I get it completely stripped hopefully tomorrow. Then I have to finish the Western Auto radio cabinet I have been working on.
I have to work outside and weather seems to always be a problem. Hot, wet or too windy.
Threads: 69
Philco 91 Tuning Condenser
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM
Transistors are easy.
Or touch your fin...morzh — 04:25 PM
