Philco 650 RF Transformer
I am working on a 650 that has a RF transformer with an open primary. My dilemma is the can is stamped 38-6916 and the parts list, #11, says it is 32-1709. Which part number do I ask for? Thanks.
Rod
Restoring Philco 96
There are currently 7759 online users. [Complete List]
» 2 Member(s) | 7757 Guest(s)
