Unknown Philco
Hello, all.
Just picked up this radio and am wondering if anyone would know which model it is.  Pictures are attached.
Thanks in advance for any help you can provide.
Dave
59S if its 4 tubes as it appears in the photo or 54S if five tubes. See: http://www.philcoradio.com/gallery/1936a.htm#e
Bob beat me to it.
59S it is - four tubes. Thank you, everyone.
Are you really Doc Severson? Hereeesss Johnny, and Doc!
Dave Severson, Castro Valley, CA.
Carl Hilding Severinsen, Arlington, OR.
Close, but no cigar.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
