Model 60 cabinet pictures.
Hello all,  I am refinishing a cathederal model 60. looking for pictures so I can get an idea of what this should look like. Somone painted mine white (OUCH). Thanks in advance for your help. Norman
Hi Norman,
Which variant of the model 60 is it? There were a number of different style cabinets. You mention it being a 'cathedral model'. This page summarizes the evolution of the 60:
http://www.philcoradio.com/tech/60evol.htm
BTW - It would be helpful (and interesting!) if you could post a picture of yours. Icon_smile
Thank you Nathan for the info. Mine is the 60B (1935/July 1934.Just imagine it painted white with red accents. will try to post a picture later today if i can figure out photobucket. Norman
Great! This is the photo gallery entry for your model:
http://www.philcoradio.com/gallery/1935a.htm#ad
Here's a thread discussing the appropriate toner colors to use on what looks like the 1936 (June 1935) model:
http://philcoradio.com/phorum/showthread.php?tid=7005
According to the info in the gallery ( http://www.philcoradio.com/gallery/1936a.htm#f ):
"...the five-tube Model 60B is identical to the 1935 version except for the larger escutcheon and different dial scale on the 1936 model."
So I would think that info should still be correct for yours.
Thanks  Nathan   Norman
There are currently 9955 online users. [Complete List]
» 2 Member(s) | 9953 Guest(s)
