ID of Philco's
All, Here are 3 pictures of some Philco radios. I cannot find a model number on any. Can someone please ID ?
Thanks
Skip...
[Image: http://i292.photobucket.com/albums/mm38/...bhzoyl.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...snhlof.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...lc6f1i.jpg]
Found at antique store..
Alll 3 are post war sets. 46-1201, or so, 47-1230, and a 46-350. You can find them here  http://philcoradio.com/gallery/#list
Terry, Ok thanks.. the one looked closer to a 46-1209 ..
instead of a 47-1230..
Skip...
 The first set could also be a 48-1201, which was the same set but with some miniature tubes, and slug tuned IF cans, I believe that the B+ voltage was higher as well.
http://www.philcoradio.com/gallery/1948a.htm#w
 The console is a 46-1209 and the last set is a 46-350, unless it has an imitation alligator covering then it would be a 48-360.
All, Ok thanks.. Just a quick Question.. What are these worth.. Consider them Not working..
So I know what to offer..
Skip...
All, Ok picked up all three radios for 25.00 each.. Cabinets are not in great shape. But radio itself looks OK.. Will not know until I start to pull apart.. Parts are probably worth what I paid..
Thanks
to ALL
Skip...
Philco 89 indicator light.
There are currently 9755 online users. [Complete List]
» 1 Member(s) | 9754 Guest(s)
