Philco 90 arch veneer
I have learned that the arches of the Philco 90 cathedral were made with oriental wood veneer; any idea where I might be able to acquire some of this? Or what might be a suitable substitute? Thanks,
Doc
I am not sure there was any veneer...at least on some of them it looks like a plain stained plywood.
Correction- the fronts of the arches. It is definitely covered in a veneer because one of my arches is missing about half of it. In a post from 6-18 one of the posters said the veneer was "oriental wood"  so that was my clue.
The sales literature is often a good source of information about the type of wood veneer used.
In the case of the Philco 90 cathedral we can look to the 1931 sales card flip book:
http://philcoradio.com/phorum/showthread.php?tid=13735
So you're on the right track with 'oriental wood'. Maybe this?
http://www.oakwoodveneer.com/oriental-wood-veneer.html
"Oriental Wood Veneer is a walnut-like wood with darker stripes and a hint of red and some figure. It is also known as Australian Walnut and Queensland Walnut."
I think Mike is talking about the rear arch, Doc is talking about the front arch. Maybe????
Yes, you're right Terry.
Sorry, Mike. I didn't specify front arch. I wasn't even thinking about that rear. Yeah, it's just plywood. And Nathan , thanks for the info.
Doc
PM sent.
M R Radios   C M Tubes
Problem solved!
