Philco 46-1201 Restoration
Threads: 140
City: Lansdale
State, Province, Country: PA
All, I am starting on a 46-1201 Code 126 I noticed something that doesn't appear on schematic ?? I think..
[Image: http://i292.photobucket.com/albums/mm38/...v2z0ih.jpg]
Lower left hand corner of picture.. Here is a closer view..
[Image: http://i292.photobucket.com/albums/mm38/...kxurb1.jpg]
Any clue on what this is.. Just curious before I take chassis out..
Skip...
Threads: 69
City: Kansas city, MO.
Looks like something someone added on. What for, don't know. The wiring on the top side of the chassis and how clean it is looks like it might have been restored at some point.
Threads: 140
City: Lansdale
Ok, Got chassis out of cabinet.. Opened up the unknown item.. Looks like resistors.. With 3 terminals..
[Image: http://i292.photobucket.com/albums/mm38/...au6z3p.jpg]
It has a Philco part number But I cannot read it.. One of the wires attaches to Pin 8 of the 35L6 tube..
Hard to see where other go. Here is bottom of Chassis.. Looks like a big mess..
[Image: http://i292.photobucket.com/albums/mm38/...dmkzl9.jpg]
So not sure if I will proceed with it.. Doesn't seen to follow the schematic I got from Chuck.. Maybe I will just sell it for a parts unit??
Skip...
Threads: 337
City: lawrenceville nj
skip
that's a candohm I think that's how its spelled
their is more then one schematic for that set
what is tube line up
sam
Threads: 11
City: Bellmawr, NJ
power resistor,,,,,but we have no schematic to tell you which one,,,I hope ,,the smarter Gentlemen will Chime in here to help you out,,,,these sometimes short out to there casing ,,it has 2 resistor readings on this one ,,,I presume,,I had one go to short ,,to the chassis bolt on,,,which it should not read ,,anything----I think
Threads: 69
Ok that's an candohm resistor. I haven't seen one in that location before. Maybe someone here can help out with why it is on outside the chassis. usually they are riveted to the inside wall of a chassis.
Threads: 140
City: Lansdale
Thanks All, Tube line up is 7A8,7B7,7C6,50X6,35L6..
It say its a Code 126 Run 3..
Also has different IF transformers..32-4161-1
Skip...
Threads: 337
Threads: 69
I don't know if this will help it has some info that might. I can't find a code 126.
http://audiophool.com/Misc/461201.pdf
Threads: 268
Well if it is tied to pin 8 of the 35L6 it very well be the cathode resistor. Most of the time it's not more than a watt or so.
Threads: 242
City: West Bend, Wisconsin
Skip, I've restored 5 of these 1201's. Three 1946's and a 1948 48-1201. Since the 1946 model 46-1201 was sold during 1946 & 1947 (there wasn't a 47-1201), a ton of changes were made to the circuitry during the first two years of production. Ron had posted ZIP file listing the changes for each code here:
http://www.philcoradio.com/phorum/attach...hp?aid=800
I've never seen a code 126 either, but you can look at the changes between code 125 and 127 to see what is different. The part (external resistor block) in question is indeed factory installed. With regards to your chassis, I wouldn't say it's a mess at all. You're fortunate that it has all of the original factory installed caps. It even appears the electrolytics are the originals. That makes it easier to follow along with the schematic / parts location. The chassis is just "a bit" cramped.
Threads: 140
City: Lansdale
All, Thanks for all the inputs. Since I have all the caps I might as well do it..Looks like I will have help here in-case I run into problems.. And since the newer parts are indeed smaller it will be easier to see whats underneath.. I do have all the paper work from Chuck. It doesn't have much on code 126.. So we will see if I can follow along with the prints..
Thanks
Skip...
Threads: 140
City: Lansdale
All, Question about this Capacitor..
[Image: http://i292.photobucket.com/albums/mm38/...e9mpuz.jpg]
It has a coil around it.. Its a .2 MF.. C403My replacement id a .22 and its about 1/4 of the size this one is.. Do I need the coil? What is its purpose?
Here is schematic..
[Image: http://i292.photobucket.com/albums/mm38/...5dh1ap.jpg]
Thanks
Skip...
Threads: 268
Was thinking about resistor issue and it acures to me that you only have 103v worth of heaters to heat. So I'm thinking that it's connected to heater (pin 2 or7 rather than 8 which is the cathode) The tap is for dial lamp??
The coil around the cap you can skip, just connect the cap to B- or ground.
Threads: 140
City: Lansdale
Terry, Ok let me look again.. I think the resistors are R100A and R100B .. At lease the values match..
This uses a 50X6 instead of a 50Y6GT so the pin numbers change..
Let me look to see where the wires really go to.. I probably had it going to wrong tube??
Skip...
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
Mike, give this site a look for your spider. Can't hurt.
Take care and BE HEALTHY! -GaryGarySP — 12:41 PM |
Rod,
Bubble packaging? The one I know (if you mean the large bubble type) is really thin. I have some at home.
Is there...morzh — 12:23 PM |
Q8. What's the meaning of life?
I have read that someone made a spider out of the clear plastic from bubble packagin...RodB — 11:07 AM |
So,
Q1. Does anyone know where to get the spider.
Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM |
The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM |
There are currently 8350 online users. [Complete List] » 1 Member(s) | 8349 Guest(s)
