Philco 370 Chairside - Veneer Questions
Nathan
Great job on the top veneer! Icon_thumbup Icon_thumbup Icon_clap Icon_clap Icon_wave
Looking very nice Nathan!!!
Thanks very much guys! I'm lucky there was a bit of that corner left - it helps those patches blend in. Icon_smile
There are currently 7304 online users. [Complete List]
» 1 Member(s) | 7303 Guest(s)
