nice,simple 2-tube compressor schematic:
I found I needed a compressor to keep all my various CDs output levels the same at the input of my homebrew LPAM transmitter. By adding this simple compressor, allows me to run full 100% modulation from my LPAM xmitter, without having to make input adjustments from various CDs recorded output levels.
I found a nice-simple schematic online that works very well! Thought I would share it here. Most vintage radio restorers/techs will have the parts needed for this project onhand in your scrapboxes. The ac trans is not shown in the schematic, but ( adding it),..is simple to understand. I used a small ac trans with 117-125 v primary, and 150-ct-150 hv secondary, with a 6.3 volt tap for filaments supply.AC trans HV rect c.t. goes to chassis ground. Rectification is via (2) 1N-4007 diodes + to tubes plates via 1 connection point from trans h.v. leads. AC hum is filtered via a 100uf/ 350 v cap at B+ to chassis gnd.
As for the variable-resistors, I used a spare 1-M audio taper, & for the 25k, I used a good spare linear taper. It works well.
The 10uf electrolytic in the schematic , I used a spare 350v type. I used new carbon/comp 1/4 watt resistors throughout, and added a couple used 1/4 in female switchcraft connectors for hookup.
Heres the very simple 2-tube compressor schematic: ( many other good schemats at this site also!)
http://www.triodeel.com/comp1.jpg
Icon_wink
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
