Threads: 3
City: Bethany, Mo.
Hi all....that's my question...can you wash photofinish??? I had four or five radios at an antique store that suffered a fire. None are fire or heat damaged but all are soot covered. Three are Philco radios; a 42-340, a 42 PT-3, and a 49-500. Two have photofinish, the 42 PT-3 is covered with it. Can it be cleaned and how??? My thanks in advance....
Threads: 242
City: West Bend, Wisconsin
I have used GoJo or Goop hand cleaner on cabinets with a photofinish and then wiped with a damp sponge without problems.
Threads: 268
Interesting questing. I think it depends on the condition of the photofinish. Badly worn or spotted finish maybe a bit problematic to clean up. If it's in good shape I would use some water on a cloth to clean, wouldn't rub really vigorously.If you like bubbles a bit of baby shampoo will give you a little more cleaning action but is still pretty mild.
I have a few Philcote sets that where spotted badly but was able the use some acrylic paints to touch up these areas. Afterwords gave it a few lite coats of lacquer to blend the touch ups. Turned out well.
Threads: 26
City: Hayward, California
Hmm, it is hard to say. We had a fire and I know that soot is one of the hardest things to get cleaned off. Usually the finish comes off with it,it is baked on too. Try the gojo that was suggested. Probably your best bet.
(This post was last modified: 08-26-2016, 01:36 PM by
Warren.)
Threads: 154
City: Westland, MI
When we had a house fire, the insurance clean up crew washed down the house quite well using TSP (trisodiumphosphate) mixed in water. Mix some in warm water, dip, then wring out a soft rag, and try it on a small area before attacking the entire radio. If they are as bad as you seem to indicate that they are, what have you got to lose? Take care, Gary
