e- cap question
Working on re-capping an RCA 816k chassis, and someone in the past has replaced the e-caps with Mallory cans.
I have one that is a Mallory FP-214.
rated at 50 mfd and 50 mfd.
The voltage marking on the can is rubbed off.
The schematics don't specify voltage on the parts list.
Anyone know what the voltage should be on caps 53 and 54?
murf
Mruf, it is always nice to add a link to the schematic when asking questions such as yours.
Jerry
http://www.nostalgiaair.org/Resources/155/M0015155.htm
Murf
The two caps are listed as having 368 and 359V across them respectively.
This means they can experience close to 500V surge at cold startup.
I would use 500V rating.
Ok,
Thanks for the help.
murf
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6747 online users. [Complete List]
» 1 Member(s) | 6746 Guest(s)
