Halson Radio
Hey Guy's
I have a Halson radio kinda a cross between a cathedral and a tombstone. I have no data and can find no model # the tube lineup is 80, 45, 27, 24A, 24A, 24A. The vol looks to have been replaced and is also toast my question is since I have no print is there a guess that can be made as to the value? The connections look to be left tab to power transformer and IF can, center to Chassis, and the right to a terminal strip through a resistor to one of the 24A tubes. Will post some pictures soon.
Eric
Kirk is the local Halson specialist Icon_smile and the local afficionado Icon_smile
Here are some pictures I've cleaned (removed the mice crap) up the chassis and replaced the electrolytic's. It plays somewhat, If I clip an antenna lead to one of the tops of the 24A and I get stations. The tubes all test good but like I have said I have I can't check resistors as the color code does not make sense so it is probably before they  standardized so I have no idea as to the value. Any help would be appreciated.
Strange thing: usually a chassis would rust on top but remain clean underneath. This is one is the opposite.
Those resistors look like you would use the body - end- dot... to read.
For instance the resistor looks like a brown one in lower left of picture with a black or blue end and a red dot in center.
Which would be 1000 ohms. if end is black, if blue 1600 ohms.
Don't think it's a superhet but a TRF set. I looked around and couldn't seem to find it in Rider's or in some of my old service books. Not too much of a big deal as the circuit is pretty basic.
(10-03-2016, 05:49 PM)KCMike Wrote:  Those resistors look like you would use the body - end- dot... to read.
KCMike
Most of the resistors are solid color no end color or dots that's why I thought they were before the color code came about in the mid thirties and am hesitant to change them.. Had one that had an ink stamp with 2 megs on it that read almost 4 megs so I changed that one.
Eric
(10-03-2016, 05:16 PM)morzh Wrote:  Strange thing: usually a chassis would rust on top but remain clean underneath. This is one is the opposite.
The top was really bad but I cleaned it up.
may have sat on top of Steam radiator????
Or inside of it? Icon_lol
 Nice cabinet, from panel appears to be stump walnut veneer. In any event it's a TRF set which is pretty typical of the early 1930s, three tuned RF amplifier stages, one detector, audio output, and rectifier, a trip through the Rider manuals will probably find the exact model. Halson was a North Eastern regional make more or less, they made everything from cheap AC/DC sets with curtain burner line cords to fancy 12 tube tombstones, and everything in between.
I do like the cabinet too. It is really unsophisticated in an intentional way, looks very rustic, goes well with an old country hotel room. Will look great when restored.
I cant understand this post?
I see it is a Halson but yet.... I dont own it?
See the issue there? Icon_lol
Older Halson's used the BED resistor labeling. I actually have a few that are like yours but through measuring the resistance and getting help from here on what the resistor attached to. I found them easier to replace than trying to figure out what the paint on the resistor body was telling me.
Again.... Why do you own this and not me? Icon_twisted
Me
Owning a Halson, Kirk, is like a Russian roulette, 5 times out of six you own it, but there's that one time when it goes to someone else Icon_lol
As an example I have two resistors that are totally blue, no end color or dots they read 28k and 27k and two brown resistors one 310k and 236k
I looked at a couple of prints that had the same tube lineup and they had 10k volume pots right now I have a 30k in there would I be better of with a 10K?
Eric
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5114 online users. [Complete List]
» 3 Member(s) | 5111 Guest(s)
