Philco 19/ 89 Schematics
Ron and All,
I know you have made some changes to Philcoradio.com. I used to rely on the section that had the various versions of the Philco 19 / 89 schematics. But I cannot seem to find that any more. Could I still get a link to those sections, or can you tell me where I still might find them.
I acquired another Philco 89 cathedral, and I'd sure like to have that info.
Thanks Ron for you great work!
Mark K8KZ
(10-10-2016, 09:21 AM)markmokris Wrote:  Ron and All,
Mark K8KZ
Ron,
It looks like I can get what I am looking for here in the Technical section.  Sorry!  I see it now.
Thanks Ron!
Mark Mokris  K8KZ
For anyone else who can't find it:
Evolution of Model 19 - http://www.philcoradio.com/phorum/showth...?tid=15008
Evolution of Model 89 - http://www.philcoradio.com/phorum/showth...?tid=15002
Evolution of Model 60 - http://www.philcoradio.com/phorum/showth...?tid=15007
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9234 online users. [Complete List]
» 3 Member(s) | 9231 Guest(s)
