41-295 rubber wire
What type and gauge wire should I use to restore this radio??
Thanks
Welcome to the Phorum!
Icon_wave
See this thread:
http://philcoradio.com/phorum/showthread.php?tid=14959
(10-10-2016, 02:26 PM)klondike98 Wrote:  Welcome to the Phorum!
Icon_wave
See this thread:
Thanks, found it right after I asked my question. I appreciate the response though.
Question, is there a heat shrink better than the others or radio shacks multi colors will do??
I've never used Radio Shack's heat shrink other than their black. I've bought the colored heat shrink from Justradios.com
It takes a little longer to get to you because it comes from Canada and has to go through the boarder crossing routine. Other folks may chime in with their suppliers.
Heat shrinkable to me is a remedy for cases when nothing else works. Like a rubber wire going into a potted transformer or a coil.
In chassis, point to point, I would re-wire what I could.
Typically AWG 20 is a pretty universal gauge; in large radios where tubes use lots of current for filaments, like 2-5A strictly for those I would use AWG18.
(10-10-2016, 05:49 PM)morzh Wrote:  Heat shrinkable to me is a remedy for cases when nothing else works. Like a rubber wire going into a potted transformer or a coil.
I'll certainly use that advice Morzh.
Questio: would you use solid or stranded wire??
Either one is fine. Obviously stranded will take a bit more abuse if flexed repeatedly. Not that it is often the case.
Solid forms better when you need it to follow a certain route, keep the shape and not buckle.
matter of preference for me.
Philco 89 indicator light.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
There are currently 6328 online users. [Complete List]
» 2 Member(s) | 6326 Guest(s)
