Another Model ID Request
What model is this?
I believe that's a 42-327T:
http://www.philcoradio.com/gallery/1942a.htm#l
Wow, 2 minutes,  that has got to be a record time for a reply. Thanks.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
