Model 60 tone colors
Working on a 1935 model 60 cathedral and am wondering what is the best Mohawk toner colors for the front which is two-toned?
Here's a pic I found online to illustrate the two shades:
I was thinking maybe perfect brown for the inset and maybe some shade of walnut for the main part of the front but am wondering what others have used? Also would the top and sides be the same shade as the main part of the front?
Thanks!
From this thread:
http://philcoradio.com/phorum/showthread.php?tid=7005
"Medium Brown Walnut and Perfect Brown, both the "Ultra Classic" (dye) toners from Mohawk."
Ron had a good diagram there too.
Thanks!
There are currently 9959 online users. [Complete List]
» 2 Member(s) | 9957 Guest(s)
