37-610 "Bullet" Cabinet refinish
(10-28-2016, 05:13 PM)OldRestorer Wrote:  I think it is beautiful......
BUT......
I dont like the white lettering on the cabinet Icon_lol
Seriously,
Very nice Job Jeff
Me
Thanks, Me. Coming from someone whose cabinet work I admire, I consider that a good compliment. Icon_thumbup Maybe someday I'll be as fast and good as you at it. Icon_biggrin
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Ok, Flattery will get you nowhere.... Ok, I lied, Icon_lol
If you seal before grain filling it will work as Ron stated.
Icon_thumbup Icon_thumbup
Philco 91 Tuning Condenser
There are currently 10064 online users. [Complete List]
» 2 Member(s) | 10062 Guest(s)
