Philco model 90
#31
Kirk thank you, I always appreciate any pointers on what I can do better. I see what your talking about and there is some dents but also I need to redo parts of the channels. Looks sloppy when I look closely. The spot on the arch is actually a small piece of missing veneer that the camera lighting made appear white.
Here's a couple close up pics of it and the coulombs. Thanks for pointing it out.
[Image: http://i1336.photobucket.com/albums/o654...fiv2b1.jpg]
[Image: http://i1336.photobucket.com/albums/o654...5v8gyb.jpg]
[Image: http://i1336.photobucket.com/albums/o654...esrgd6.jpg]
#32
Mike
Did you mean the columns? Icon_lol
The coulombs are usually hidden inside the capacitors Icon_smile
#33
  Icon_lol  You're right. I've got to quit reading so many radio books before bed.
#34
Hmmm,
  I am glad that was not a paint fleck.
The columns do look like better in your new pics..
I think it is a few dents that were tricking me?
I think you did a fantastic job.. Getting paint out of grains is no easy task...
Icon_thumbup Icon_thumbup Icon_clap
Me
Philco 91 Tuning Condenser
There are currently 9277 online users. [Complete List]
» 1 Member(s) | 9276 Guest(s)
