Philco Mic? Speaker? Model Number?
Can anyone identify this mic?  or is it a speaker?  It has a three wire cord.  Bottom number is: 28-7324.
I can't say for sure but found this one that's similar.
http://www.ebay.com/itm/Vtg-1930s-PHILCO...SwknJX0ukR
Hi Wilbur Icon_wave
It could be either a microphone or a speaker, really.
These were used with Philco Beam of Light radio-phonographs that had the record cutter attachment as a microphone.
They were also used with Philcophone intercoms of the same period as a combination microphone and speaker.
excellent, thanks for the info..... i don't need it, i will probably list it on e bay. it has three wires, i will try to test it first.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
