Philco 84 code 121 no sound
Threads: 268
(11-14-2016, 10:25 PM)Mike L Wrote: Ok I'll give it a try. The few stations received are very very weak, So I feel there is something else going on too. I ordered a set of tubes to see if I might not have an issue there as well.
As far as using the signal generator is concerned, am I measuring output to the speaker with my VTVM? I have the alignment procedure, but It just states adjust for peak signal, but where? I'm also not 100% sure my SG is working properly either. With it connected to the grid cap of the det-osc tube, SG set at 460kc all I get is a low pitched squeal around the 460kc and 1000kc spots on the tuning dial. Nothing anywhere else.
Set radio dial at 550kc. Set sg dial at 460kc. Adjust #11 and 15 for max sound from spkr. Keep sg signal to a minimum as you adjust 11 and 15 for peak.
Threads: 9
City: Springville NY
State, Province, Country: NY
I'm stuck. Adjusting 11 and 15 has minimal effect. I literally have to put my ear next to the speaker to tune or hear a station. Here is what I have done lately:
Replaced all tubes, one at a time with no change.
Re-checked all voltages, all fall in line except that now the 2nd detector plate and screen voltages are "bouncing" around. They are not stable. The plate is around 60 and the screen is around 34. I tried another tube with the same result, slightly different readings but still bouncing. Checked and rechecked all grounds, all were good.
If by chance I re-wound the feedback of the oscillator coil backwards would it receive stations at all?
Before rewinding the coils I had nothing, just low level hum. After rewind I'm receiving a few stations on the low side of the dial, nothing on the high side, but all very very low, barely can hear them. The volume control is always at max.
Threads: 268
Replace 1M resistor and check #20 to make sure that the two caps are wired correctly. When the det 77 and output stage 42 tube are working properly should get a loud buzz when the grid cap of the 77 is touched. Wouldn't sweat the osc coil till we get this sorted.
Threads: 9
Threads: 69
City: Kansas city, MO.
I'm sure Terry will get back to you. It looks to me like what you said about the 0.015 should go to pin 2. The way it is now, it is grounded.
Threads: 268
The caps inside 20 are wired incorrectly, only the .001 is grounded. You have two connections from the caps grounded. Please wire as per the schematic and not the Philco p# cause it's the wrong one.
Threads: 566
The cap is wired NOT as per sch. The 15nF section is the DC blocking and CANNOT go to GND.
Your problem is, you need to look into
http://www.philcorepairbench.com/bblokcap.htm
here to the original 7762-B. If you have other cap, adjust the pinouts accordingly, the OEU pinout is not gonna work.
Threads: 268
I don't see any 15nf caps anywhere!!!!!![Image: http://philcoradio.com/phorum/images/smi...on_eek.gif] Yes his signal from the detector stage is not connected the the output stage wired in this configuration hence very low volume.
(This post was last modified: 11-20-2016, 12:00 PM by Radioroslyn.)
Threads: 566
(11-20-2016, 11:57 AM)Radioroslyn Wrote: I don't see any 15nf caps anywhere!!!!!![Image: http://philcoradio.com/phorum/images/smi...on_eek.gif]
Oh come on Terry.  Tell me that you don't know what a Megahertz is. And I am not referring to the verb meaning "it hurts a lot
Threads: 268
Sure I know!!! Whatda think I'm stoopid er sumptin!!
It's very large rental car![Image: http://philcoradio.com/phorum/images/smi..._crazy.gif][Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
https://www.youtube.com/watch?v=GLpNmuPQE94
(This post was last modified: 11-20-2016, 12:40 PM by Radioroslyn.)
Threads: 9
That was it!! Lots of volume, finally had to turn it down. Also receiving stations all across the range with just a 3' wire antenna in my basement.
I cant remember where I downloaded that cap block information but it was obviously wrong. I rechecked the others as well against the schematic and those were correct. Now I'm going to have to go back to my 80jr. to make sure that is correct since I used the same information on that one.
Pretty sure my signal generator is not working correctly so I went by ear to adjust 15, 17 and 11. After that project is done I'll come back and do a correct alignment.
THANK YOU Terry and everyone that contributed.
Threads: 268
Your welcome! Glad you got it sorted and working now your model 80 should be a piece of cake. Pretty much the same set except that it uses tetrodes instead of pentodes for the mixer and detector. I just noticed something the model 81 is the same vintage but it uses pentodes. I've got an 81 in the back room that need servicing. 81 is a two band version of the 80.
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
There are currently 7182 online users. [Complete List] » 3 Member(s) | 7179 Guest(s)
