6B1000 tube settingz
Hickok 600
settings for a 6b1000?
Got it 6BE6   6AL 5   6.3 JR-0730-0 BIAS 0 ENG 78 PRESS P1
                                           JR-0205-0 BIAS 0 ENG 78 PRESS P1
http://www.antiqueradios.com/forums/view...p?t=131680
                                BIAS     ENG  PRESS MUT COND
6BE6    JR 7562-3       0        35        P1      800
              JR 3602-7    20       9O        P4    6500
Found this link
As an update to this I have an example that is marked 6B1000 AND 6BE6 with a brand marking that says Jewel, "made in the USA". They are also out of a Freq. Generator.
They do not respond to the test (2 diode) for a 6AL5
They test good as a 6BE6 osc. and about 50% on the 6BE6 amp (2 tests).
Eico 232 VTVM Schematic
