Threads: 140
City: Lansdale
State, Province, Country: PA
Found this Philco Type 60 Code 121.. However I cannot seem to find a picture of it anywhere.. Meaning the Cabinet. Did they make different cabinets for these? The knobs appear to be different also..
Here are some pictures..
[Image: http://i292.photobucket.com/albums/mm38/...ixaotv.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...vs3m3i.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...qiyixq.jpg]
Thanks..
Skip...
Threads: 214
City: Seattle
State, Province, Country: WA
Yup...the final version of model 60 Baby Grand from mid-season 1936.
Nice and clean.  Get a shield on that 78 tube before you fire it up, else it will squeal like crazy.
Threads: 140
City: Lansdale
Ron and ALL, Thanks for the info..I do not have the radio yet. What would be a good price to offer? I like the style. This would be my first one of that kind..
Any thing I should know about it??? Would Chuck have info on it?
Skip...
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 140
City: Lansdale
Thanks I will look thru it..
Skip...
Threads: 140
City: Lansdale
I noticed that this set uses a lot of Backlite Caps. Values in some are .00011 ..( 110 PF)
What type of Cap would you use for them.. I cannot seem to find that value except maybe in Silver Mica?
Plus the voltage rating seems to be 1200 volts on some..
If I do get this radio I want to have caps in stock..
Also there is a Big wire wound Resistor # 47 at 35 Ohms and 235 Ohms.. I am sure if its bad I cannot get those values.. Wattage??
Condenser Bank? .09,09,05,.5 Waht caps do yopu use for them??
Sorry for all the questions but this is the first Radio of this type for me I hope??
ANY CLUE ON WHAT TO OFFER FOR THIS RADIO?
Thanks
Skip...
Threads: 214
City: Seattle
The 110pF should be replaced with mica caps. 500V should be fine.
I believe they may be mica caps to begin with (encased in tar), but I usually replace them with new caps just to be sure.
I'll let others reply on the other questions.
Yes, 500V is more than fine. You could even go as low as 100V and still be OK as these will normally see very little voltage.
The earlier bakelite blocks using 110 pF caps actually had paper caps inside. Later versions used mica. So you can use mica or ceramic as replacements. They are not part of a tuned circuit so value and stability is not critical.
Quote:Also there is a Big wire wound Resistor # 47 at 35 Ohms and 235 Ohms.. I am sure if its bad I cannot get those values.. Wattage??
It's probably good, and if so, leave it alone.
If bad - 5 watt should be sufficient; less for the 35 ohm section (maybe 2 watts).
Quote:Condenser Bank? .09,09,05,.5 Waht caps do yopu use for them??
For .09 uF use 0.1 uF.
For .05 uF use .047 uF.
For 0.5 uF use 0.47 uF.
All 600 or 630 VDC yellow Mylar tubular.
Threads: 140
City: Lansdale
Ok, After checking on the OSC and antenna coils. They appear to be open..
Transformer looked OK Didn't check the IF cans..
Since I cannot rewind coils and its sounds like a PITA.. I guess I will pass on the Radio.. Unless I can maybe talk Terry into rewinding coils???
If not It will be available at the get together this Sun for Terry and Friends,,
Skip..
Threads: 140
City: Lansdale
Thanks For moving this..
Skip...
Philco 89 indicator light.
Well thankfully that did not happen.Jim Dutridge — 05:21 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
Mike, give this site a look for your spider. Can't hurt.
Take care and BE HEALTHY! -GaryGarySP — 12:41 PM |
Rod,
Bubble packaging? The one I know (if you mean the large bubble type) is really thin. I have some at home.
Is there...morzh — 12:23 PM |
Q8. What's the meaning of life?
I have read that someone made a spider out of the clear plastic from bubble packagin...RodB — 11:07 AM |
So,
Q1. Does anyone know where to get the spider.
Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM |
There are currently 6474 online users. [Complete List] » 2 Member(s) | 6472 Guest(s)
