Big, Bad*s*, and ugly 660L
#61
Been following along during your restoration Terry and really enjoyed it and learned from it also.
 Can only add: Great job Icon_clap
#62
+1 Icon_thumbup
Also: Black knobs are correct for 1936 Philco sets.
(12-03-2016, 04:51 PM)Ron Ramirez Wrote:  +1 Icon_thumbup
So all of the oval escutcheon sets should have black knobs? Learn something new every day!
Radioroslyn Wrote:So all of the oval escutcheon sets should have black knobs?
Correctamundo.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7450 online users. [Complete List]
» 3 Member(s) | 7447 Guest(s)
