Philco 16 escutcheon screws
Where could I get some? Or should I just get any two of appropriate size and paint them brown?
Did you find the escutcheon?!!
I probably have a few... I will look but how big? How big is the hole in the escutcheon and is it a recessed screw?
I will look tomorrow.
Ed Schutz made me one, should send it tomorrow.
Small screws, the thread would be same as any cath Philco escutcheon, the head is almost spherical, for flat screwdriver. Dark chocolate brown.
Ok, I checked my stash and I have these...
I feel like they will be too small but they fit all the other escutcheons perfectly
They will be in the mail Monday
Me
Thanks Kirk, these will likely do fine. I will slather a copious amount of brown shoe polish I bought for shining brown backelite on top to make it look shiny brown Icon_smile
Darn, I could have toned the tops....
The mail was late so I got them out in time..
shoe polish? ack!
Oh I'll just let them rust, that will do the job of toning.
There are currently 11404 online users. [Complete List]
» 2 Member(s) | 11402 Guest(s)
