680X back cover?
Does anyone know if the 680X late model from 1936 originally came with a back
cover over the speaker area of the cabinet?
Thanks in advance.
Rod
I have the early and late 680's and there is no indication of a back... 37 was the beginning of that practice except for a few earlier models with the "echo absorbing screen"... as far as I know, others please chime in!!
Jim
No mention of one in the 680X sales brochure either:
http://philcoradio.com/phorum/showthread.php?tid=15816
Thanks for responding, could not find anything indicating a back was
installed on the radio either.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
