Philco 54-6182-1 part number
Threads: 566
It's Kirk's. Dunno what the radio model is (small white clock radio).
Need the sch or at least the IF value.
When clock disconnected seems to receive but very whistly and howly.
Also the 12BE6 pentagrid is very weak.
http://www.philcoradio.com/phorum/showth...p?tid=9215
Surfaced up here before.
Threads: 310
City: Kings Park NY
It is a Philco 1955 white plastic 720. This color is the C-720, there is also a D-720...
I cannot find ANY info online. The only reason I know the model is from an original 1955 clock radio AD.
It is pictured int he 1955 section of the Philco gallery.
AC: 4 DC: 1
Threads: 566
Kirk gave me two 12BE6 that are strong.
The radio clearly needs alignment.
Threads: 566
Well, here's some. Although there are some mistakes there.
http://www.introni.it/pdf/Radio_diagrams_1955.pdf
I found some in DjVU format but cannot get back on that website - forgot what it was. The same manual though.
The 720 is said to have the same sch with
C580 or C716. While the PCB does look the same format-wise, it only has 4 tubes and ours has 5 tubes.
However C-722 sch does look similar, 5 tubes with the 12BE6 pentagrid and clock connection.
Could be it!
Threads: 310
City: Kings Park NY
Woohoo!
Now Fix it,
AC: 4 DC: 1
Threads: 566
(12-27-2016, 12:06 PM) OldRestorer Wrote: Woohoo!
Now Fix it,
Everything I find on the web on 720 shows the wrong sch although with the same size/format PCB. It is a 5-tube radio and 720 is listed with the rest of 4-tubers.
Actually even in Sam's Photofact here
http://www.todocoleccion.net/radios-anti...~x31883793
OK, well, hopefully the sch is right of what I have found for C-722.
Not tonite though.
Threads: 566
OK, you dummy.....
It is a Philco D730.
http://www.philcoradio.com/gallery/1956.htm#s
And this is the sch.
http://www.techpreservation.com/schematics/Philco.htm
I converted it to PDF.
PS. And, yes, I was right before: the C-722 schematic is practically the same (minor differences) and the tube line-up is the same.
Threads: 310
City: Kings Park NY
Hmmmm,
I only went by online and the pictures I found...
Good detective work...
AC: 4 DC: 1
Threads: 566
That will cost you a console cabinet!
A big one.
Threads: 310
City: Kings Park NY
You are too funny
AC: 4 DC: 1
Threads: 566
Wait....two cabinets. Both chassis involved detective work.
Threads: 30
City: Wellborn Florida
Will try and upload sch file size is 956kb to big! David
Threads: 30
Try try again. Hope this helps. David
Threads: 566
David
Thanks but it does not help. As you could see from this discussion the radio is either not 620 or the sch is not from 620: the radio I have is a 5-tuber and is likely a .730.
Yours is 4-tube radio.
Might you by chance have the 730 sch with good resolution? (I can live with what I got but resolution helps).
Threads: 566
Anyway
Attempted alignment tonight. IF was a bit off. Cannot peak oscillator at 1620 kc.
Plus during the tuning the cap really makes grinding noises. Maybe I should clean the dang cap. Plus tubes' pins and sockets. It's a simple radio but it behaves strangely.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM
RCA T62 is playing.....
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM
Philco 40-120C Restoration
Philco 89 indicator light.
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM
There are currently 6197 online users. [Complete List ]» 1 Member(s) | 6196 Guest(s)
