Threads: 567
This has a TH-4 chassis.
So far the speaker is shot. The sad thing is is the voice coil and the magnet - the rust got in, ate away the coil and the paper bobbin, freezing the cone (doesn't even matter). Sad because of both the field and output xfmr are good.
So....Kirk said he'd be looking for a 4" speaker for this one. It is possible that other than alignment this one wouldn't need anything.
Threads: 567
Question:
Would the speaker from a 40-125 (it is a field coil one with 500 Ohm coil, and also driven by 35A5 so the output transformer should be the same; but do not know the mechanical challenges that might arise / size, mounting holes etc) fit in this?
Someone is selling a pair of these radios in my corner of the woods; for $50, I might try to knock it down a bit.
Threads: 337
City: lawrenceville nj
mike
a 40-120, 124, 125, 501or 502 will work
if you can`t get it cheap I have a 40-125 in storage
sam
Threads: 567
Thanks Sam.
It's up to Kirk, if he wants to spend money on it and how much. This radio will need a new speaker; short of re-coning there isn't much that can be done and re-coning price-wise could be more expensive than buying another speaker, even if with radio attached to it
Threads: 337
mike sent pm
Threads: 567
Got it, replied.
Threads: 567
So...?yestersay when I attempted the power up some magic smlme escaped from some place. I suspect it was a coil. I didn't bother to find out what it is, some RF xfmr though not sure which, maybe oscillator.
I checked continuity, still good.
So I replaced more wires, found some errors.
Today checked the tubes again, some croaked but I have 40-125 now that is a donor of...everything.
So I powered up, and it works. There is a motorboating sone place in the middle of the band, I think I will attempt alignment and see if it improves. Tomorrow.
PS.
The speaker is exact replacement. Seems like all of them used the same one. And the chassis' are not that different from each other.
PPS. This radio is the ROYAL PITA. I HATE IT.
Threads: 337
Mike
If it is as easy kirk would do it
Heck I see it and I don't want to do it
Threads: 567
You need to come over and pick up that coffin with the asbestos sheet inside
PS. Kirk does it anyway. First. Before giving it to me. That is one of the problems with this radio
Threads: 567
Forgot to add: need to open the volume regulator to fix the switch.
PS. The hope the volume pot could be taken from 40-125 did not materialize: the same exact problem.
Threads: 567
Opened the pot, cleaned both the resistor and the switch, closed and soldered over the riveted lugs of the switch: they were a bit loose and this resulted in contact resistance increasing to 300 ohm which could result in losses.
While doing this, had to replace more wiring.
Now it is working OK.
THE END.
PS. Need to really clean up the place: lots of crumbled insulation and even some pieces of asbestos.
Threads: 337
good job mike
just throw asbestos and wire bits in kirks radio after all it his right
sam
Threads: 567
Some of it is yours
Threads: 337
I like to share so give him mine
Threads: 567
OK. One asbestos sheet goes to Kirk.
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
Ooh, very nice!jrblasde — 12:19 PM |
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye.
It has 13 tu...Dan Walker — 12:07 PM |
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM |
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
Blister Pack, that's what I was trying to remember!RodB — 09:29 PM |
There are currently 7668 online users. [Complete List] » 2 Member(s) | 7666 Guest(s)
