Possible transformer fix!
I copied this from another web site and thought I'd pass it along. Love cheap easy simple fixes, to a problem Had a input transformer slowly develop a physical hum recently. All voltages were fine, just noisy. Pulled the item out and boiled it upside down in a pan on the stove for about 45 minutes until the tar potting material softend up to the consistency of playdough. I was able to basically repack the material from the opened bottom of the otherwise sealed transform can. Left it to cool, it rehardend of course. Reinstalled: quiet as a mouse. Your experice may be different but worked for m.
tractorforum.com *** I reserve the right to be wrong
Thanks for the tip! Icon_smile This should be good for those of us who restore radios other than Philco - as far as I know, none of Philco's audio transformers were ever encapsulated in pitch, but a good tip nonetheless.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4768 online users. [Complete List]
» 2 Member(s) | 4766 Guest(s)
