Philco 60 tuning shaft slips
Threads: 3
City: Yukon, OK USA 73099
Almost done with a model 60. The gear reduction tuning shaft slips at various points. I have cleaned and oiled the bearings to remove any sticking of the capacitor but still get some slip. Any tips on how to clean or fix this?
Thanks
BTW; this work would have been almost impossible without the model 60 evolution information available here. THANKS!
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
I did a 60MB not too long ago and was looking at my pics, unfortunately I did not take a lot of the tuning shaft mechanism, just what was in my thread.
UPDATE...I had the wrong URL to the above thread...corrected now.
Threads: 567
You take off tat bell-shaped cap where the tuning shaft enters. Be careful not to spill the balls when have it opened.
Clean everything. Put the bell back and tighten. I am not sure there should be any grease inside. I usually leave it dry.
Threads: 3
(01-09-2017, 03:18 PM)morzh Wrote: You take off tat bell-shaped cap where the tuning shaft enters.
OK. Good to know! I did not see that the bell could come off. I will give it a try tonight after removing tuning cap so I can keep the balls under control.
Thanks.
Threads: 567
You don't have to remove the cap on account of the gear. It is quite nicely accessible with just the dial off.
Unless you have to remove it anyway, than sure.
Threads: 3
(01-09-2017, 03:48 PM)morzh Wrote: You don't have to remove the cap on account of the gear. It is quite nicely accessible with just the dial off.
Yes, I was planning on removing it anyway since the rubber mounts are shot and need to be replaced. It was helpful to have it on the workbench and keep the balls from wandering off. I took them out and cleaned inside the shaft with a q-tip then cleaned the inside of the bell cap. It all makes sense now. The bell shaped cap is the race for the 3 balls that make up the friction drive / gear reduction and the bell is held on by a copper leaf spring which gives the tension for the drive. I had not seen a mechanism like this before so I added a bit of knowledge.
However I am finding at my age that my memory has saturated and for every new piece I get something else leaves. Sadly I don't get to pick what bit goes away. :-)
Thanks for the tips!
Rick
Threads: 567
Like Kelly Bundy
Threads: 3
Another bit that puzzles me. The tuning cap is isolated by the rubber feet, but then has a ground strap soldered to the rear mounting screw by a braided ground strap directly to the chassis. This is a very awkward setup. You have a screw that has solder all over the top making it difficult to remove. Why not just ground the frame of the cap to the chassis directly? I am thinking of putting aluminum or brass spacers under the cap. Is there a valid reason to shock mount the tuning cap??
Threads: 567
The rubber grommets are NOT to isolate the cap but to remove the microphonics. You have to understand the function of something you question before reworking it.
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
Mike, give this site a look for your spider. Can't hurt.
Take care and BE HEALTHY! -GaryGarySP — 12:41 PM |
Rod,
Bubble packaging? The one I know (if you mean the large bubble type) is really thin. I have some at home.
Is there...morzh — 12:23 PM |
Q8. What's the meaning of life?
I have read that someone made a spider out of the clear plastic from bubble packagin...RodB — 11:07 AM |
So,
Q1. Does anyone know where to get the spider.
Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM |
The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM |
There are currently 6615 online users. [Complete List] » 1 Member(s) | 6614 Guest(s)
