philco model 111
i have schematic web searched cannot find wattage on resistors found some that compare pics i have black 10,000 siver gray yellow tip 100,000 orange 50,000 belgium blue 13,000 brown body blacktip red dot 1,000 battleship gray 500,000 white 250,000 jade green 70,000 auto brown yellow tip 25,000 long tudular 10,000 short tubular 800 flat wire wound 2 sections 70 omhs thanks abushel &apeck mr schwark for the answer on my other topic Icon_exclaim
See this page from my website regarding resistors and also use the comparison pictures link to help.
http://www.philcorepairbench.com/carbonres.htm
New member
Philco 630csx power cord
New member
There are currently 3451 online users. [Complete List]
» 3 Member(s) | 3448 Guest(s)
