Threads: 140
City: Lansdale
State, Province, Country: PA
Ok Started on this Philco..
[Image: http://i292.photobucket.com/albums/mm38/...enrkga.jpg]
I managed to get it apart not easy.. But found this...
[Image: http://i292.photobucket.com/albums/mm38/...aevsqq.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...0wjmzj.jpg]
Obviously not original...
But first problem.. How do you get this tube out? It has a shield that will not come off.. I tried twisting, pulling, prying ETC but will not budge.. Whats the Trick?
[Image: http://i292.photobucket.com/albums/mm38/...e26gev.jpg]
Skip...
Threads: 567
Doesn't seem too densely packed.
Threads: 54
Try squirting some WD40 or other penetrating oil between the tube shield and it's base, it's probably rusted on. I don't know if this is one of those but some tube shields had a sort of bayonette lock on them where you have to push down and turn to get them off, however those usually had a spring inside, alternatively you may have to rock the tube shield back and forth to get it off, but try the WD first.
Threads: 268
Use a small flat tipped screwdriver. Insert it over one of the rivets. Give the screwdriver a little twist forcing the shield upward. Should pop right off.
Threads: 310
City: Kings Park NY
I almost bought that one...
AC: 4 DC: 1
Threads: 140
City: Lansdale
Yup I am surprised you didn't.. Terry suggestion worked.. took some effort but it came off..
If that didn't work then I was going to try Arran's ..
Thanks
Skip...
Threads: 140
City: Lansdale
Ok, Finished the Recap . Brought up on Variac to 117 Volts drawing about .25 Amps.. So all looks good. Started receiving stations all across dial. Sounds good.
Next waiting on some Novis polish to get cabinet back to looking good..
Skip...
Threads: 140
City: Lansdale
Quick Question Just received the Novus 1,2 3 polish.. Is it also good on Bakelite cabinets?
Skip...
Threads: 140
City: Lansdale
Well, I am not impressed with the Novus products.. It will not even take out small scratches.. Waste of Money...
Unless I am using it wrong.. Any tricks I should know of??
Skip...
Threads: 271
City: Wilsonville
State, Province, Country: OR
I have gotten good results on the clear plastic dial covers, especially when they are cloudy. If you can see the scratches they will take a lot of rubbing with the #3 product and even then i can not always get them out.
Threads: 140
City: Lansdale
Ok, Finished this. Recapped and all out of Tolerance Resistors replaced.. Very Sensitive.
Cabinet cam out OK.. Not perfect But no to bad..
[Image: http://i292.photobucket.com/albums/mm38/...rzvqtj.jpg]
On to the Next...
Skip...
Threads: 271
City: Wilsonville
