Philco 3650
The Philco pickings have been really slim in my neck of the woods but I finally came across something today that will be a worthy project. I look forward to the day I can start on it. This is the Canadian version of the model 650., see below.
Gregb
Nice find. Icon_thumbup
That's in beautiful condition. Congratulations on a great find!
Gregb,
Very nice!! Cleanup, I hope, and not a refinish?
Nice clean specimen!
Nice set and it looks like it has one of the easier shadow meters to rewind too!
Thanks for all the comments. Steve, I don't refinish unless there is no saving the original. The top and base will need some work for sure but I think I can cleanup the rest.
Gregb
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
